94 crank no start
Darascal101
Walker, LA
If I can't do it...find someone to teach me
I am at the end of an engine swap but no start. 1 question is if I have the timing off would it start when I shoot fuel straight into the intake but not when I just crank it. I seem to have pressure at the schrader valve but I am not sure how much. Also according to my timing light I have spark. I am pretty sure I have compression, but I will verify after I go to the store and get a compression gauge. I am open to any suggestions at this point. Just added note when I got it to start by shooting fuel into her there was no back firing.
fuel pressure when cranking is 40psi/ when i just turn the key on to let the pump prime but no crank 20 psi
30-40psi fuel pressure is correct for 1986 thru 1997 Ranger engines
But fuel injectors still need to open so that fuel gets into the cylinders
Spark timing matters of course, having spark is good but if it is at the wrong time then no start, even if you add fuel manually
1994 3.0l has separate spark and fuel delivery
The TFI module and distributor do the spark
Then PCM(computer) opens the fuel injectors
In 1995 and up these were combined into the larger PCM(computer, it did both spark and fuel delivery
If you timing light flashes when in #1 spark plug wire, then is it flashing when #1 TDC mark is close to 0deg BTDC?
i.e. marks on the crank pulley and front engine cover
How old is the gasoline in the tank?
5 months old and its no longer "gasoline", the part that burns has evaporated away, its more of a varnish now, so no start, and it can also foul New fuel you spray in manually
Yeah I have definitely let it set for more than 5 months and it definitely smells of varnish. It will start when fuel is manually added. Like I said in my edit if I don't crank the engine then I only get 20 psi at the rail when I turn the key on. I am thinking I am going to pull the fuel pump and try changing just the sock and adding some new fuel after I get rid of the old fuel before I put the money out for a new fuel pump. Any input or advice is appreciated
On the bright side the old fuel DID NOT sit in the injectors that long because I removed all of them from the rail and cleaned them and then replaced all the orings
Drain as much fuel as possible, use it as weed killer(not great for environment), or in a lawn mower, a little bit at a time mixed with fresh gas
Then add fresh gasoline to Ranger tank, 10% ethanol mix is best for this, 5% OK as well, straight gas no ethanol will not mix with the water in the tank so you will get stumbling until most of the water is gone
20psi key on/off is fine, anything above 10psi will get start up, with fresh gasoline, and then pressure will come up to 35psi average once engine starts and fuel pump is on full time
Thanks!! Appreciate the input
My experience is that gas goes bad in about 2 months! An easy way to drain your tank is at the fuel filter which is under the drivers seat. Just disconnect the input line and loosen the filler cap, and it should run out. Might help to park on an incline too. Yeah, the varnish smell is not good!
thanks
