- Nov 4, 2009
- marquette, MI
- Automatic
The truck as it sits right now, this is updated as the truck progresses the build is in the page's that follow
94 mazda b4000 reg cab shortbox
4.0l , M5OD, 1354M
pvc snorkel (I am a plumber after all)
straight pipe 2'' exhaust with the last 5 feet being 4'' give's it a deeper tone
31 spline 9'' spring over and
Ballistic spring perch's and shock tab's
chev 63'' rear spring's with a 4" block
front 77 F-150 dana 44 high pinion
homemade rear driveshaft
factory front driveshaft
homemade trans crossmemember t-case protection (of sorts)
rusty's off road "high clerance" long arm's
79 F-150 6" deaver super flex spings
37x14x15 IROK bias with full size missmatched spare
steel wheel's
crossover steering
custom highlift mount flushed into the bedside
custom front & rear bumper's
Delta second hand plastic tool box CAME WITH KEY"S
smittybilt xrc 8000 winch
2 hella offroad light's (front) 2 fog lights(rear)
custom tail/turn/brake lights (sick of breaking factory one's)
cobra cb with weatherband 36'' whip on front bumper
custom on board air (DIY)
since im waiting on somemore parts to arrive i figured i would stat a build up of my Dana 30 swap
i am only handling the minor welding as it will be going to a buddys machine shop for all the solid welding... i am only capable of making two pices of metal stick together not of making two pices into one as he calls it
I am using a dana 30 non-cad out of a 96 XJ , it is a high pinion with the larger u-joints 5-760 i plan on running eb coils since they are the closest to the size i need, 19'' at ride height , these will be 21'' (super flex 5.5'')jeep coils is what i would perfer but the longest one's i can find would be 16'' (rustys8.5-9)
after the front end removed along with all the brackets,arms,beams,and crossmembers(tranny)
The new front axle from the local scrap yard
Rusty's long XJ arm kit (high clerance)
Flex joints
some other work i did while in limbo ..
mini truss and some gussets on the ''weak'' front axle
.BODY ARMOR (ok so it was some rust repair/reinforcing)and i know the welds look like poo its 1/8'' plate and was having a heck of a time welding it to the body
http://hphotos-snc3.fbcdn.net/hs039.snc3/12633_365380155133_715295133_10075088_937910_n.jpg
and my barbaric bead breaker
4.0l , M5OD, 1354M
steel wheel's
crossover steering
Flex joints
