B3000SE
I just did a Compression Test This Morning it was spot on 142 across all cylinders,Replaced the Thermostat,did a flush,made sure all the air bubbles were out of the system by running it with the Rad Cap Off,I even re Gapped the Plugs,Everything is as it should be.I took a 60 mile round trip on a Flat highway,and on the way back I turned on The A/c(85 Degrees outside) and almost instantly the temp gauge took off toward the hot mark,This Truck Is driving me crazy ! It runs 10 Degrees hotter off of The middle and Takes forever to warm up..... I am stumped ! Does Anyone have any Suggestions to help me from losing my mind ? Thank you for anyone willing to take the time to throw some Ideas at me........
