94 ' b3000. 506k miles. Fuel Injectors.
Texas
Injectors and regulator are original. Trying to correct a stumble at idle. Pump within limits. Have run out of things to seal, adjust or replace and generally this vehicle runs smooth. Stock upper intake. Looking for suggestions on a suitable injector replacement options within the stock pressure range.
I'd consider an opportunity for a mild enhancement.
Instead of replacing them, you can send them off to be professionally serviced and balanced. Cheaper and you know the results before you put them back in.
This is a daily driver. My everyday commuting truck. In fact, I drove it today. So any injector project I undertake would be done within a weekend.
