94 4x4 lift questions
Masteryeti
Wheelersburg, OH
Im a new ranger owner was wondering what lift would give me enough clearance for 31x10.5 to 32x10.5 tires? dont wanna go to big seeing how this is my everyday driver.
that chart is a bunch of BS if u ask me, i had 33 12.50s on my stock as a rock 93 4x4 they did rub the radius arm but it had to be flexed really hard. so in my opinion 31s or 32 would fit fine
the chart is an overall general idea... different vehicles are different. depends on the springs and how much they've settled, so on.
do the washer lift and belltech 6400's and you'll probably have more then enough room for the 31's.
I had 30s when i got my 94. They cleared just fine. 31s should clear stock no problem.
My 97 came from the factory with 31's and a two inch lift on the rear axle. No issues, and I believe the 2 inch lift can be removed and not have any fitment problems. take a look at the link in my sig if you want to see what it looks like.
AJ
i have 33x12.50 on my 94 ranger with a 3" body lift, and i have a ton of room left, i shoulda went 35's lol
Before my truck got a real suspension, i had Daystar 2" coil spacers, and 31x10.50R15. Looked good, sat level, and no rubbing.
On a side note, as long as my D35 stayed together, it went anywhere. Open rear axle, welded front axle, full circle snaprings, welded u-joint caps, c-clip eliminator, Warn hubs.
Sent from my PG86100 using Tapatalk 2
2wd reg cab vs 4x4 sup cab
I sold my 94 reg cab 2.3 2wd in favor of a 94 super cab 4.0 4x4
It came with 31x10.5R15 already mounted
(though worn down to the last mile of tread)
plenty of clearance with stock suspension height
What's funny is once I mounted new (stock suggested size ) tires 235/75R15 the speedo is now 4 mph off (slower)
The 31s put the speedo about spot on.
Well at least now if I'm speeding (according to the speedo) I'm really not (according to the laser gun). ;)
might try spacers on the front and go from there as long as they don't rub fully flexed ill leave it at that
