David 78
- May 3, 2016
when i crank it cold it will start and then die then start it again annd barely touch the throttle it will run and after it warms it will idle but when i give it over a 1/4 trottle its sluggish and plays catch up on response i changed the maf sensor helped a little i was wondering if maybe my fuel pump is not sending the correct psi or should i be checking something else
