bcammons
How pliable are they supposed to be.
I was doing brake lines in the truck and while I was doing them I was tapping the "rubber" part of the engine mount with a screwdriver and it felt really hard.
Then I used the end of a breaker bar and when it would hit against it it made a clunk sound.
Ive got a slight grind/vibration coming from the motor or trans that has been there since I got the truck. I am figuring that the mount on the right side is probably the issues. (The truck has new brakes and bearings as well as u-joints.)
The noise gets worse when turning to the left at speed but goes away when off the throttle.
