chalkoutline
- Nov 2, 2009
- Automatic
Greetings
I have a 94, 4 cyl Ranger, 200K+ miles. It will crank, but not start.
A couple years back, a similar situation happened. Ended up being the Fuel Pump Relay. Since then, I've bought 2 replacement relays due to the re-occurring problem.
This time a new fuel pump relay isn't curing it.
Here's what I've done/verified/checked so far:
My Haynes manual has a few suggestions, but I'm not motor-proficient, so I get a little tangled up on what something looks like and where it's located.
The manual suggests:
A couple of gas tanks ago, I also added in some fuel system cleaner since I was experiencing rough idling (which didn't cure the idling). Could something have clogged enough injectors (or something in the fuel system) to create this condition? How would I test that fuel is getting to the injectors? I don't smell gas from the engine when I try to pump the pedal during start, like I sometimes have experienced.
As far as the manual goes:
Testing for fault in injection system - the only test I can perform, since the engine doesn't run, is to check the electrical resistance to each injector. Should I bother or does something else seem a bigger priority?
Excessive moisture on, or damage to, ignition components - I tested for spark on one wire and got some. Should I test more spark plug leads just to make sure?
Faulty coil pack - I got spark, as mentioned earlier. Again, should I test more spark plug leads? How else can I test this?
Sorry for such a long post, but I wanted to be thorough. Like I said, I'm not mechanically-proficient, but I can follow instructions. I just have a problem with where things are located and what they look like.
Any other suggestions or thoughts would be much appreciated.
- Cleaned battery terminal connections. VERY corroded. Used Coke and Water.
- I can hear the fuel pump priming
- There is fuel pressure on the engine side of the fuel filter
- There is fuel pressure at the fuel pressure damper (on the fuel rail)
- Removed the air hose coming from air filter box to ensure air
- Checked all fuses in the relay compartment under the hood on drivers side
- Checked for spark from a single spark plug lead. Got some, but it was orange.
- Checked for any obvious loose electrical and vacuum connections. None found. "Obvious" meaning from what I can tell without digging under components.
- Battery had a full charge yesterday when I began tinkering.
- Timing belt, from what of it I can see, looks OK.
- Fault in fuel injection system
- Excessive moisture on, or damage to, ignition components
- Worn, faulty or incorrectly gapped spark plugs (ruling this out due to all-of-sudden vehicle death)
- Broken, loose, or disconnected wires at the ignition coil pack or faulty coil pack.
