tbunch
I'm probably abusing the need urgent help section, but I am working on this right now and need a little input.just completed full rebuild, new everything. Been breaking it in and have only put about 10 miles on it and I have an active drip. Since I've totally cleaned and painted everything I figured it would be a snap to identify the leak... Silly me for thinking things would be easy!
When I run the engine at 2k Rpms I am getting oil beading on the bottom edges of the driver side motor mount bracket, right next to the oil pressure sender. I've ruled out the level sensor as its bone dry and the leak is clearly above it, I feel like the pressure sender is dry too and I used thread sealant on it to make sure it didn't leak. All I can think would be dripping onto the mount bracket would be the valve covers, but the're bone dry as well. (So are the head gaskets)
The leak appears to be isolated to the driver side, towards the front and is running down the cross member and dripping off the center. I can't see any seepage from the timing cover either and the front crank is not dripping or throwing oil. I realize this is like asking to find a needle in a haystack so I'm really just trying to get any similar experiences so I don't end up pulling the motor out, or ripping everything off it again, just for kicks
Any help/ideas are appreciated!
