MA Ranger
- May 19, 2009
- Automatic
My 94 3.0L (2WD, automatic) has developed a whining noise that I believe is coming from the transmission. It was leaking fluid - I repaired the leak and added about one third of a pint of fluid to get the level back in the "normal range" on the dip stick.
Before and after the repair/adding the fluid, the transmission shifted normally in all gears and appears to be operating normally with the exception of the whining noise. Adding the fluid had no effect on the noise. When I checked the fluid level, the fluid on the dip stick was "normal color/smell" - no indications of burning ( I have changed the fluid every year since I bought it new). The noise is a lot more noticeable when driving at low speeds in the lower gears (like in a parking lot or when starting from a standing stop).
If the transmission is the source of the noise, how much damage am I looking at and is replacing the transmission the only feasible repair. Thanks
