- May 14, 2018
- Western Mass.
- 3.0 V6
- Tire Size
- 225/70/R15
- My credo
- If it's not broken Don't Fix It!
This spring I need to do a set of valve covers so the upper intake will be off and I'm considering cleaning the intake the best I can while it is apart. The upper cleaning because it is not on the engine at this time is easy and safe but the lower is where my major questions arise.
Because the engine has 150K + on it I know the intake has lots of oil build up in it, lower more than upper due to a good cleaning with it on the motor, is it possible and safe to try and clean the lower intake with it installed on the engine. My thoughts are big chunks falling down to the tops of the valves and then into the cylinders after the cleaning?
If it is not safe to do so with it on the motor I will do an intake cleaning on it after words. I am just thinking that because I am already that deep can the lower be cleaned safely.
