LeftOfSanity
- Jun 7, 2011
No Oil pump sproket, has Auxillary sprocket.
Does the Aux sprocket control/run the Camshaft Postion sensor? The Camshaft sensor is nowhere near the camshaft.
its down below intake near #1 cylinder.
When replacing a broken timing belt does the Aux sprocket need to be aligned a certain way?
I've seen online that it didnt matter, should be pointing straight up, or should be pointing towards cam mark.??????
