'94 2.3l not firing on 1 and 4
iank1
'94 2.3l 5 speed no AC California emissions. Some time ago I tried the advice of swapping the wires on the exhaust side coil (front secondary coil) so that they all spark on the fire stroke. Today I realized that my primary coil was not firing on one and four. So I swapped the two coils with one another and got the same result. The coil in the primary position doesn't fire on one and four, no matter which coil is in that place. WHY!?!?! :bawling: I've tested the ICM and supposedly it's good. :bawling:
You probably shouldn't have moved the plug wires. Maybe try moving them back to their original position. This mod doesn't do a whole lot anyways...
