SkiLLzWheeLz
- Oct 16, 2008
94 2.3L --- 8 plugs --- coil packs
Under WOT it will backfire and bog down. Under normal gas it will still bog. Driving down the road it will bog unless I give it just a tiny bit of gas (enough to barely accelerate). Idles fine it seems but will still backfire most of the time if given extra gas. IT DOES not do this all the time, but day by day it seems to do it more often. If I turn the truck off and restart most of the time it will get me back up to speed but then starts screwing up again. I dont have a check engine light BULB and all I have is a digital voltmeter to try and read codes....not having much luck. I hooked it up and I could see the volts jumping but not sure how to read it exactly. I do know how to read codes on the CEL when flashing.
Changed so far........fuel filter today...man it was nasty...maybe due to SeaFoam last night and just being old. Spark plugs changed. Changed Timing belt. I have coil packs...no dizzy. I had the problem before these were changed.....just got a little worse lately
Sorry for the long post but I want to give as much info as I can. Thanks!
Going outside right now to test plug wires.
