93 Ranger 4.0 V-6 Cam Position Sensor
bojo34
Headland , Al
Ok Guys Here Is A Good One. I Replaced My Manual Tranny . In The Process I Broke My Cam Position Sensor Plug On The Sensor Side.so I Removed The Top Part Of The Sensor. The Engine Was Not Moved And I Was Able To Epoxy It Back On. Now, When The Engine Warms Up It Runs Rough And Skips When Driving. The Exhaust Is Extremely Hot, To Hot. I Checked The Wire On The Cam Position Sensor And They Are Not Shorted To Ground Or Each Other. Codes With A Scanner Are 177,176,and 332. What Is The Easiest Way To Check The Output Of The Sensor And/or Timing. Any Help Would Be Appreciated.
