JonH
- Jul 13, 2024
- Washington state
- 4.0 V6
- Tire Size
- 41.5x13.5R17
93 ford ranger xlt is a frankenstein of a truck. Engine and 5 speed trans are stock. Not much else is. Built for offroading. Doubler dana 44 9 inch on 41.5s
Wheeled all day on the trails. Started and shut off(turned key off) at least 15 times. Drove on to trailer. Started, drove off trailer. Turned key off. Hosed off mud on body and underneath. Did not hose Engine bay. Started. Parked in driveway and locked up. 2 days later crank no start.
Pulled out Chilton book to troubleshoot.
Hooked up timing light to check spark.
No spark.
Verified fuel pump makes noise when key on.(also fuel smell if I crank and crank)
Has 12 volts to coil pack with key on.
Ohm tested coil pack. Passed. (Installed new anyway cause I had one)
Verified trigger signals to coil pack from EDIS
Checked ohms of crankshaft position sensor and wiring. Sensor had 15.48 M ohms.
Replaced crankshaft position sensor.
Still crank no start.
Verified ohms of new sensor (and wiring) passed.
Proceeded to test EDIS (ICM)
Checked power to terminal 8 pcm relay. Good
Checked continuity of terminal 9 and ground. Good.
Checked resistance of crankshaft position sensor and wiring (again) good
Tried another known good EDIS. No change.
Book says check circuit from ignition module to spout connecter terminal 3. (I think is typo) suppose to say pcm?
Have not checked that yet.
No OBD1 codes present. Does have the all good 111 code.
Check engine light turns on with key on and shuts off when cranking.
All fuses and relays test good.
While cranking, have noticed a few times with timing light hooked up no spark while cranking but as soon as I turn key off 1 flash of timing light followed by backfire.
Any help greatly appreciated.
No spark.
