93 Ranger 4.0 4x4, XLT - rotor removal
montydaweasel
I am trying to replace the rotors on my 93 4.0L 4x4 5-spd with manual locking hubs. I got the hub wrench, and I loosened the first nut, but behind it there is a single washer and then another 4-prong nut. I am stumped. Please advise how to get the rotor off without destroying the wheel bushings?
Yep... The washer should pull off, and then there is a second almost identical nut behind it that should only be about finger tight. The inner nut has a small nipple on it... MAKE SURE you take note of this, as it locks into the middle washer upon reinstall!!!!
Good luck!
