Airman9911
- Jan 2, 2017
Hey,
As the title states my ranger will not idle unless you feather the throttle, and even then it doesn't want to. It will immediately die, until the engine starts to warm up, if you stop feathering the throttle. So far I have changed the idle air control valve, the fuel filter, and the throttle position sensor, and have cleand the butterfly valve on the throttle body. None have helped. Did change the plugs when I first got the truck 2 weeks ago, and that helped it run better after the engine had warmed up. Any help would be appreciated. Truck has 323k miles
