Combs Customs
- Aug 8, 2007
- Age
- 39
- West Chester, Ohio
- 1993 / 1993 /19
I haven't got any pictures online yet, but i need to start a construction thread for my sploder. It's the one in my sig, originally a 4.0L / A4LD / 1354E truck. Everything else stock besides some rear lift shackles and lots of miles. Saturday March 29th I pulled the entire drivetrain out.
The 4.0L needed timing cover gasket, oil pan gasket, and a rear main seal replaced. So i went ahead and put in a new timing set and oil pump. The reason to pull the motor now was to do the M50D / 1354M swap. Upgraded the clutch and PP to a Centerforce unit.
I bought a 6" BDS front lift from another local member. Once i get new rear spring plates, shocks, and brake lines the lift will be going on. Hopefully in a couple weeks.
Thanks for reading, will get pics up soon. Still gotta get everything back in and running, you know, to get to work and stuff.
