Ingandreal
I have a 1993 Ranger ext cab w automatic trans and 4wd. I also just aquired a 1993 Explorer Sport 4wd Trans. Both have/had a 4.0 infront of them. Now i just need to know what all is gonna need to be done other than hooking up a clutch pedal and hydraulic system, swapping the floor pan, removing auto shifter, flywheel and clutch assembly installed and bolting up the new 5 Speed onto the Ranger. Im pretty sure that theyll fit together without any adjustments to the drive shafts and what not. I also wonder about the computer because i would beleive that unplugging the auto trans would make the computer throw a code and not pass inspection. If anyone knows of a write up or could give me good feed back on this i need to know asap. Trans is givin out quick in the ranger and i drive alot so i dont wanna be stuck on the side of the road.
