RanchRanger
- Jan 11, 2016
- Automatic
Hello everyone, I'm new here and this is my first post. I'm a farmer and rancher from rural Montana and last week I picked up a 93 ranger "prerunner". It has a 4.0 and auto from a 98 ranger, full cage, fiberglass, and tubing from the front to back over the stock frame. Underneath the front is camburg 4.5" beam kit with king 3.0 coilovers and 2.0x4.0 bumpstops. The back has a deaver 5 pack, flipped shackles, and currently has some stock shocks from a f-350
. I'll probably never go racing due to the distance but I have plenty of room to get crazy right here at home. I'm very fortunate to have most of the necessary metal working tools to do most anything and during the winter months I actually have some spare time. I'm planning up a four link and need some direction, there is literally no one in the area that has a clue about these things. It currently has a ford 8.8 with lockers, 4.56 gears, and disc brakes, I also have a 9in with posi from the factory and drums laying around. Not sure which ill use yet, which ever one i chose I'll do a homemade truss for. To start I was thinking of building some temporary brackets with the leaf springs still on that would allow me to take the springs off and leave the axle location in place. Giving me room to make the lower and upper links and brackets. I've been doing a lot of research on design and such and here is where my questions come in. I plan on doing 1" uniballs on the forward lower links and and 1-1/4 heims on the back. I have a lathe and plan to make delrin cups or doughnuts for the uniball to fight link wobble. Now when building the link mounting the coilover and damper above the center line would make fabrication of the links much easier than beneath the center line. Will the delrin cups and top mounted coilover be a problem or do I just take more time on the the lower links and build for below the centerline. Another question is where to put the front lower link mounts. Idealy they would be at the center of the u joint to fight axle plunge. Although I have a sbc 406 and two wheel drive turbo 350 in a shed somewhere, and i know at some point I'm probably going to get the urge for and engine swap. Oh and getting back to the back half. I was thinking that once the rear axle is mounted I would then chop the back off and start building upper shock mounts and possibly a small flat bed, although it will have some tubes going through it. I have a lot to think about and any comments and welcomed. Thank You
