93-97 tails off eBay, turn signal hole only has 2 tabs
ejholmgren
Bought a pair of 93-97 tails off eBay because the truck had Altezzas on it when I bought it (not my style). Went out in the cold to see if I could swap them quick, but the hole for the turn signal bulb on the new lens has two notches instead of three. Is there a bulb that will fit the two notch hole with the same connector for the harness?
Hrmmnn ... rockauto lists the rear turn signal socket as being a two prong. Problem solved. Maybe someone switched to the 3 prong socket to run the Altezzas.
i had the same problem when i bought tail lights for my f-150. just took a dremel to it gently where i needed the indent to be. works just fine for me :D
