birchfur
- Mar 30, 2009
I have 95 ext cab that's dropped 3/6. Was wondering if anyone has converted to one piece driveshaft from newer rangers. The article in tech library talks about it for 4x4's but not lowered rangers. If you have, did you use any pinion shims? What is pinion angle?I had center ujoint straps come apart while driving and now after replacing there is alot of vibration, so I think shaft might be bent from bouncing around on pavement, would like to replace with one piece if posible.
