93 6 inch skyjacker
homegrownranger
Florida
One of my buddies wants to trade me his skyjacker 6 inch for my 351m but Im not sure if it will work on my 92 ranger or not? Thanks in advance
It should fit fine, all the way up to 97 the rangers all use the same lift
Thanks for the responses guys. This is awesome now ill take my 4in rough country off and put that on for 10 inches all together!
Um...I don't think you understand the total idea here. You can't add lift up to get ten inches. If you remove a four inch and install a six inch, you still have six inches of lift. The only way you will get more is if you use eight inch springs and a two inch body lift. Oh, and that is not recommended either.
Yea I know that, I should have reworded it. I have a 3 inch body lift and I have an extra inch block in the back and a washer lift along with the rough country lift. That gives me 8 and now since Im putting the 6 inch on it will make it 10 if I leave the washers and what not in. I just made this post because I wasnt sure if the brackets were the same, and now I know. Thanks everyone. Now if I dont like it this high I can just swap out springs if Im not mistaken. I think the 6 inch brackets will work with 4 inch springs. Any way I think Ill like it.
