93ranger_prerunner
- May 7, 2010
Hey folks,
Well Im new to TRS and was hoping to get some insight on my problem with my truck.
I have a 93 ranger, with a 4.0 engine. one day, the truck started overheating on me, so i changed the t-stat, bought a fan clutch, unplugged the radiator, and it was good for about 2 weeks. then it started overheating again. fixed it once more and it started to feel like it had a misfire when i would hold the motor at about 1300 RPM, then it would stop at about 1800 RPM. also, when i start it at a cold temp, it does not idle up right until about 5 seconds after its already on. it also gives a strong smell of crude gas from the exhaust.
and now the problem is that when it gets warmed up, it begins to overheat and all of the coolant begins to leak out from the overfill tank. ive tried almost everything from unplugging the radiator, new t-stat, new rad cap, and it still does this. it does not have signs of coolant in the oil or anything like that either. and it only throws out the coolant after the motor heats up, it doesnt even throw it out when i start the truck cold without the radiator cap on.
my next guess is that it might be the intake manifold gaskets, or the head/ head gaskets. i also supect that the Catalytic converter might be clogged. before i start tearing it apart, i would like to get someone elses opinion on this problem.
any help on this would be much appreciated. Thanks.
