93 4.0 fuel pump runs with key off?
87RangerXLTct
Connecticut
2.9L
Stock
Stock
235/75/r15
Alright so a few things I’m dealing with. I bought this truck not running supposedly the shop I bought it from had it running, they said it needed a fuel pump and injectors. It was sitting for like 20 years. Just put a new pump and injectors in it. The truck won’t start off the ignition key, it’s a manual transmission I’m thinking the safety switch on the clutch pedal is causing that? No big deal I jumped the solenoid with key on. The pump runs continuously even with key off, I tried swapping relays with the a/c relay and it still does the same thing. I noticed the fuel pump relay was getting hot so I’m assuming the contacts are stuck closed?
Only other thing I can think of is maybe it needs a new ecm?
Kinda not sure of where to start troubleshooting this?
The new pump is a Delphi unit.
Any help is greatly appreciated!
Should’ve probably posted in the fuel systems forum, not sure how to change that
Update I tested the relay and it seems good, I have no continuity across terminal 30 and 87 with the relay unplugged. So I don’t think it’s the relay causing the pump to run constantly
By passed the clutch safety switch and started it off the key, messed around with the connector on the fuel pump and finally got it to cycle and behave like it should. Truck runs now but check engine light is on and abs light as well as a list of other stuff that doesn’t seem to work lol but one thing at a time, I’ll pull codes and go from there
Went to start it today and it was doing the same thing constantly running with the key off. Messed with the electrical connector and now it runs constantly with the key on.
Also the lock ring for the pump is interfering with the wiring connection keeping it from fully seating.
Hopefully the picture explains it.
I’m thinking I’ll have to modify the lock ring, and I’ll need a new connector?
  • 93 4.0 fuel pump runs with key off?
There is nothing about that connection that would make the pump run continuously. It just can't happen. A bad connection would make it NOT RUN. I'm afraid you may be looking at an ECU problem. Maybe the infamous bad capacitors.
I don’t know how it acted normal the other day?Pulled the ecu and sure enough the caps are leaking all 3.
When searching for a new/used ecm does it have to be f37f-UC or will another one work? I see on car-part.com they list 5 different ecm’s for 4.0,4x4, and manual transmission
I can't definitively answer that question. I think the last letters are just minor revision numbers and don't matter. But, wait for someone more knowledgeable to chime in.
Glad you found the issue.
Thanks for the help!
