chad
I was told today to look for a vacuum leak. Apparently, because the truck misses at idle but runs fine under acceleration (as the throttle plate opens), a vacuum leak could cause a miss on that cylinder? I know I had the stuck injector problem, which has been replaced. Could it be a vacuum problem causes the miss that is still present?
