lifesakick
- Feb 20, 2013
- Automatic
I have a 1993 ranger 3.0L 4x4 automatic supercab 140k Nice truck until now
I was driving my truck on the freeway yesterday going 70 mph when it just died, I pulled over found there was no spark, removed the distributor cap and found the rotor broke and it broke the cap also (strange but it was 6 below so I thought the cold may have done it)
I replaced the cap and rotor and it started up fine and started on my way home. I only made it about 2 miles when it started to labor badly and backfire as I pushed on the accelerator, when I floored it, it then accelerated up to speed but began to labor and misfire again as soon as let up on the gas pedal a little. I was able to make it home but it acted if it were out of time or plug wires were on wrong.
So this is what I did so far, I rechecked the firing order, checked to see if the rotor broke again (it didnt, and wires were in order) I put on a new mass airflow sensor, put a timing light on it (read 15 btdc at idle) I also set timing mark on TDC and checked rotor position to make sure timing chain didnt jump spots, I didnt have a fuel pressure gauge so I just depressed the pressure pin while it was running and it sprayed all over so I assume it has good fuel pressure, checked the fuel pressure regulator to make sure no gas was coming out of vaccume line, used ob2 and found No codes, reset comp anyway and disconnected battery also to do reset, checked vaccume lines, checked pcv, checed icv. while doing much of this it was idling and running smooth, then it started to run rough and I tried to revv it up and it backfired and labored even when not in gear, so I shut it off and restarted and then it revved and idled good again, but still acted up when driving it. I am at a total loss as to what could have happened when the distributor rotor broke and even why it broke in first place. I have never incountered anything like this before, it almost acts like the timing is way off or it isnt getting enough fuel, or even like the catalytic converters are plugged, but it was running perfect before the rotor broke, So I will ask the fellow members with all there combined knowledge for help solving this, or any suggestions. Thanks
