warmachine5500
- Nov 19, 2008
- Automatic
This isn't really urgent, but I was unsure where to put an F150 question in a Ranger forum.
92 Ford F150 5.0 EFI motor. My friends moms truck needed a new throttle position sensor (it was idling high). Her grandson put it on. Now it idles fine, but when you want to put your foot in it (going up a hill or getting on a highway) the truck will bog down. It loses power, a check engine light appears, and if you keep your foot in it it will eventually stall while you're driving. If you take your foot off and let it "breathe" the engine will idle like its supposed to, but if you try to hammer down again, the same thing will happen. It only happens when you put your foot in it. If you're very gentle on the throttle, it won't happen.
I looked around the TPS and couldn't find anything wrong or disconnected. I covered the throttle body intake with my hand and it stalled (checking for a vaccuum leak).
Is it possible the new TPS sensor is doing this? I would think if it were bad out of the box, it would idle funny. I have a feeling it's not related. Possibly a fuel pressure issue? Weak fuel pump? I took a look at the fuel filter. It looks fairly new. I have to get my hands on a fuel pressure tester I suppose, but I'm open to any ideas! Thanks!
