City_Farmer
- Dec 25, 2010
- Automatic
Okay I have my 93 up and running and it has the 4 cyl I am sure it is the 2.3?? I was told that is uses like a quart every 75 miles or so as I recall and it does smoke. After reading the tech area I see that oil consumption can be due to the valve stem seals. Should I replace them? I am guessing a compression test is also a good idea at this point. Also if I wanted to drive it a little as it is what oil type and weight would be best?? I know 5w30 is what I run in my 97. Thanks for any info.
