I am considering a second generation (1993–1997) extended cab, 2WD, manual, 2.3L Ranger. The reason is to have a lightweight flat tow vehicle behind an RV that can hold some things. In these years 4x4 manuals are restricted to 55mph while 2WDs are not. I am basing this owner’s manual information. I wanted to ask the group about something that is odd.
Notice the change in flat tow 2x4 instructions from 97-98. The 97 and 98 used the same M5OD-R1 manual transmission.
1993-1997 - 4 x 2 — Manual transmission
- Release the parking brake.
- Place the transmission gearshift in the neutral position.
- Maximum speed is limited by towing equipment manufacturer’s recommendation, unlimited distance
1998 - 2WD (manual transmissions)
- Release the parking brake and place the transmission in the neutral position.
- Maximum speed is 56 km/h (35 mph). Note: Later years increased this to 55 mph, the 35 must be a typo.
- Maximum distance is limited by towing equipment manufacturer’s recommendation, unlimited distance.
I am trying to figure out why the unlimited 93-97 2x4 speed got trimmed back to the 55 mph speed of the 4x4 in 98 onward. If it was just documentation laziness/sloppiness or if they just needlessly penalized the 2x4 units to have guideline consistency. If it is the same M5OD-R1 manual transmission, could a different engine or rear-end have caused this? If I can determine that the 55mph limit really does not apply to the 2x4 from 98-12, I could get a much newer truck. Thanks for any ideas.
