Closetcanibal
I am trying to finish my first ever major project. I replaced the head gaskets on my 1992 ford ranger 3.0 V6. I recorded the entire disassembly process so i could make sure i followed correct process to put back together.
I got everything together and had no "spare" parts left over so that is a win. I go to crank her over and she turns over but wont start. I have confirmed she is getting fuel and new plugs are damp with fuel and pump comes on after key is turned.
I seem to be not getting spark. Tonight I am going to use an ignition tester on each cylinder but earlier today i was able to crank the engine over with the starter switch while holding the spark plug in my hand.
First question is, Will using the starter switch that is jumped off the connections near the battery still allow the spark plugs to fire? i know it bypasses the fuel pump, but will it also bypass anything that helps create the "signal" for the vehicle to produce spark?
Second is if everything is plugged in and I am not getting any power at the Ignition coil where would i trace back to?
