Deppdog
- Dec 23, 2007
- Automatic
I have a 1992 Ranger with a 4.0. It has always fired right up, but the last couple of weeks it has taken a couple of cranks. All of a sudden it just wouldn't start. I found a split in the fuel line on the engine side of the fuel filter and have replaced that. It started up right after and I drove it 20 or so miles since then. Ran an errand yesterday morning, came back out and it wouldn't start. A few minutes later it started, ran fine but hiccupped a couple of times on the way home. This morning, started right up, but now will not start at all. Fuel pump is turning on, fuel is getting to the fuel rail, starts with starting fluid into the throttle body. Haven't had time to look at it any closer than that yet. Just looking for advice on where to start. Check the fuel pressure at the Schrader valve & check out the fuel pressure regulator? I would assume since there is some fuel pumping, that at least the relay and inertia switch are working properly. Any thoughts or ideas would be appreciated.
Thanks in advance!
Thanks in advance!
