georgiaboy27
Also I had been noticing the throttle under take off has been doing this sort of step acceleration thing and not smooth
I have also noticed rich burn from the exhaust as a matter of fact, I was thinking maybe the 02 needed changed, which I think I will do also...I do remember glancing at the schematics on here and seeing that "spout" on there... thanks again, I will change a few things and post up my resultsThat could be TFI/spark issue
When you accelerate TFI module gets a signal from computer on the SPOUT wire, its like "vacuum advance" on older distributors
This signal changes the TFI module's spark timing for the Richer fuel mix needed for acceleration, if spark timing doesn't change properly then hesitation and stumbling can occur
thanks Ron, great information! I will definitely follow thru with these procedures...iginiton module is on the way, and o2 is next on the listYes, SPOUT wire/signal needs to be disconnected to set Base Spark timing, same as you needed to unplug vacuum advance to set Base spark timing on older distributors
So there is a SPOUT Connector for that purpose, basically a Jumper that you pull out to set Base timing
O2s are the only sensors that wear out at specific times, 100k miles or 12 years
They use a chemical reaction to generate voltage when heated above 600degF
And they simply run out of that chemical
At end of life they produce less and less voltage, which means "lean" to the computer
0.1v = lean
0.9v = rich
So a false lean, and computer runs engine richer than it should which costs you lots of money over the years in wasted fuel until O2 finally sets a code when its "dead" or your MPG gets so bad you investigate why, lol
So always a good idea to change O2 sensor if its over 12 years old or over 100k miles since the last change
