jester1020
- Aug 11, 2011
- Automatic
Wow it's been a long day. I'll post up some pictures of stuff tomorrow. This will be the first ford I've ever built. -The short version- About 2 weeks ago my boss gave me his 92 ranger regular cab short bed 3.0 a4ld. I've spent the last 2 weeks deciding what v8 and trans I wanted to install. Since I've never built a ford motor I did give thought to buying a trans adapter from marked motor sports and dropping in a honda V6. In the end I wanted to do this as a redneck tribute to the ranger I helped my dad build when I was 15 (85 model 289 w/302 heads and a C4). I've been looking for a good 5.0L roller motor and AOD. Well today I brought the ranger home home and roughly 20 min later I found an 89 f150 5.8 5 speed for $500. Still waiting on the tow truck to drop it off but it's mine.
I've got an insane amount of crap to get done.
-swap over to 95 front spindles
-fabricate caliper adapters and have stock rotors machined down to hubs for
95+ cobra brake conversion
-find some 17" crown vic steel wheels and chromed plastic center caps
-find an 8.8 rear and order the cobra mounting pads
-find the clutch pedal assembly for a ranger
-figure out if I can use the F-150 clutch master cylinder on the ranger
-locate a pair of exhaust manifolds
-find a dual plane intake and 750 carb
-inspect motor, compression check, clutch, steam clean, etc.
-check for shifter location on F-150 trans (might be to far back)
-figure out why no air seem to come from the ranger hvac system (yes the
blower works)
-find out if a 3.0 radiator will keep the 5.8 cool. Think it has to be a 4.0
-elec fans
-hybrid the ac's to work
-oil filter the heater box
-oil filter relocation kit with cooler
-wiring WOOHOO! my favorite part
-85 front end conversion
-figure out mounting and wiring for the pristine leather accord seats I have
-figure out if I actually need to swap over to a 5 speed steering col.
-order the convertible mustang engine mounts
-need to pick out a cam (as soon as I'm sure if it's a roller motor or not)
I'm sure I'll add to the list as I go. I'll mark off the things I've done in red.
blower works)
-elec fans
