92 ford explorer
explorer_92
missouri
truck starts runs fine in idle but when i shift to reverse or drive my truck stalls...
no check engine light, i even went through 1 by 1 and unplugged maf sensor,air idle control motor,and tps sensor every one caused a check engine light.but once i plugged them in no light,doesnt sound like a fuel filter i can rev it up constantly no hesitation, now when the problem 1st started a month ago i changed my tps sensor and it worked for a month.. back too the same problem
no, i ran scan and found 4 codes,one on key on 543,and 3 engine running 129, 167, 411...
Modulator? Any ATF loss? or vacuum at intake?
Good luck
