92 F150 question(s)
rusty ol ranger
2.9 Mafia-Don
⭐Supporting Member
Michigan
2.9L
My neighbor bought his 17 yr old kid a pretty decent 92 F150 for like 1200bucks. Its a 302/E4OD/2wd reg cab long box.
Anyways....someone grenaded the driveshaft in it (why it got sold, twisted it right off in the middle....guy claimed it "rusted and broke"...yeah right)
Anyways....they put a driveshaft in it and it does move and shift through the gears.....but it shifts firm. The speedo also doesnt work and rear ABS is on.
I crawled under it found the pigtail to the speed sensor totally gone. So i fixed that for them and tossed a speed sensor in it. Still same thing.
I find it weird it shifts still with no speedo....my 97 didnt when the sensor went. Truck only has 130k so i dont think the tone ring would be bad.
The speedo does "come to life" when you turn the key on so i dont think the Speedo itself is bad. I didnt dig to far into wiring but it seemed ok besides the pigtail.
Any ideas?
Wiring could be damaged elsewhere when the pigtail was pulled on.
Do they have sensors in both the trans/tcase and rear axle?
Is there a speed sensor on the transmission? Sometimes, way back then, the one on the diff was for RABS only.
That i dont know. I figured it just had the rear axle one. Ill have to look into that.
When i get back over there ill check the wiring further up. Besides the pigtail back where i spliced it seemed ok. It looked like a mouse chewed the pigtail.
I do wonder now if that driveshaft maybe took some wires out, but all the taillights and stuff work
The body wiring would be along the frame, different harness.
So it could of possibly murdered some wiring in there. I know it did a number on the front fuel tank
One doesn't simply just accidentally twist up a driveshaft, especially with a stock 302.
Was we doing a brake stand or something? Something very well could be broken too.
Oh i know. I knew the story they were told was total bullshit.
It was leaking from the output seal but they changed that. Like i said it seems to function but the speedo dont work and it shifts firm...like its in limp mode. It does go into overdrive though and fluid is decent
I once twisted the end off a drive shaft on a 1 ton truck. It blew while I was revving the shit out of the motor going from gravel to pavement. I never did find the end, it must have shot out into the farmers field next to the road.
I did it on a semi at my old job.
They were yard trucks but still...we had a dump trailer they would WAY overload with reground block to dump back in the charge pit..(concrete block plant)....i was driving an old ford L9000 single axle with a worn out old 12.7 detroit and a 7speed. It didnt like 100k gross from a dead stop up a steep hill.
Twisted it right off before the rear yoke...rear yoke and u joint went flying 50 feet and hit a concrete safety block so hard it cracked it
I haven't looked that deep but I think the switch to only use the RABS sensor on the rear diff was around '94 so I would look for a speedo cable on the back of the trans.
I know the speedo is electronic, no cable. But ill hunt around on it when i get under it again.
I grenaded a u-joint in my F-150. I was loaded, with a loaded trailer, 300-6 and a ZF5 connected with a stage 2 or 3 clutch and a rear locker. Bent the ears on the shaft and yoke, had to give them the old heat-n-beat. Had a heck of a time trying to find a replacement driveshaft. The one local yard had 5 of them and all bent because the guys running the loaders don’t care
I bent the yoke ears on my 83...as well as pulled the u bolts right out of the spring plates.
Trying to pull a loaded 5yard 66 GMC dumptruck up a hill. Mine was 2wd so we backhoed....um...alot of dirt in the bed. The thing was so heavy that the 300/T18 couldnt budge it unless i used creeper....which i did. It moved it a couple feet then destroyed everything driveline behind the carrier bearing except for the rear diff.
A 300 with a creeper first is capable of alot of carnage lol
An 8’ bed filled with damp topsoil to the top of the bed rails weighs over 3 tons, ask me how I know, lol
