Duane867
http://www.aa1car.com/library/acronyms.htm
Yeah I made them all up. I'm good like that.
This is not meant to be a flame.......
If you were trained and certified SAE ( or knew one, or were some what familiar with standardized automotive terminology and acronyms in general ) you would know that they are indeed standard acronyms used by every SAE mechanic in the US. Not just made up Chilton, or Haynes manual acronyms. As well every acronym listed has the description of the part next to it in my posts. I like Ford as well or I wouldn't own one, but that does not mean that FOMOCO is a supreme entity for all others to follow or the SAE trained mechanics who work for them. Who coincidently learned the same acronyms because they are SAE. There is shop talk and nicknames in every garage. Ways to simplify part names and what not. There are also proprietary electrical system parts that most all automotive manufacturers use and have their own acronyms for. They are more times then not simply acronyms added to acronyms so to speak because they redesigned a standard part to make it "special". Then there are the actual acronyms every one learned ( and goes through ongoing training to be current ) for standard automotive parts. EDIS potatoes pota'toes really because we are talking about components of the EDIS ( electronic distributorless ignition system ).
This information contradicts you acceptable answers I know. Sorry bout' that. But blasting us/me isn't going to change it.
Saying the cam position sensor has nothing to do what so ever with the ignition system ( if so equipped ) is like saying the holocaust never happened.
It has every thing to do with the ignition system. It determines position and stroke of the #1 piston ( CID ) using the hall effect sensor inside it to create a signal to be used by the PCM ( power train control module ) to sequence fuel injectors. No fuel during the right TIME = no fire. I would call that ( as all mechanics do ) a vital part of the ignition system. Spark is not the only system in the ignition system. That's why they call it a system.
Now if you wanted to speak the same language what you should have said was that the CMP has nothing to do with spark in the ignition system.
You are right in that I was sending the wrong dog out to hunt for that one though for sure. But that's what no sleep gets yah.
and yes I did edit one of my posts above the same time I posted this because I was up late and mistakenly posted CKP when I mean to put CMP regarding Cali. models and Federal models that had them.
