92 3.0L EEC pinout
RangerRock
Madera, Pa
92 3.0L ECU pinout
Spent over an hour reading the Haynes electrical diagrams and this is what I came up with. Is this right?:icon_confused: Haynes did a good job makeing the 3.0L confuseing. Planning out a V8 swap and my swap project has a well worn 3.0L.
PIN COLOR Connections for 92 Ranger 3.0L V6
1 YEL +12V Battery
2 LGN Cruise Control
3 GRY/BLK VSS +
4 WHT/PNK (TFI) IGNITION MODULE
5
6 PNK/ORG GND VSS-
7 LGN/RED ECT SENSOR (Engine Coolant Temperature)
8 DGN/YEL Fuel Pump Inertia Switch / Fuel pump relay
9 PNK/LBL VIP test connector
10 DGN/ORG A/C Heater
11
12
13
14 LBL/RED MAF SENSOR
15 TAN/LBL MAF SENSOR
16 ORG DISTRIBUTOR
17 PNK/LGN VIP test connector
18
19
20 BLK GND
21 WHT/LBL Idle Air Bypass Valve
22 LBL/ORG Fuel Pump Relay
23
24
25 GRY ACT SENSOR Air Charge Temperature
26 BRN/WHT
27
28 TAN/ORG VIP TEST CONNECTOR
29
30 LBL/YEL TRANS NEUTRAL INTERFACE
31 GRY/YEL CANISTER PURGE SOLENOID
32
33
34
35
36 PNK (TFI) IGNITION MODULE
37 RED EEC RELAY +12V
38
39
40 BLK/WHT GND
41
42
43
44 DGN EEC SHORTING BAR
45 LGN/BLK BMAP
46 GRY/RED Signal Return
47 GRY/WHT TPS Throttle Position Sensor
48 WHT/PNK VIP TEST Connector
49 ORG O2 Sensor
50
51
52 ORG/YEL 3-4 Shift solenoid Auto trans Only
53 PUR/YEL Converter Clutch Solenoid Auto Trans Only
54 PNK/YEL Heater & A/C
55
56 GRY/ORG DISTRIBUTOR / IGNITION MODULE
57 RED EEC Power Relay +12V
58 TAN Fuel Injectors 1, 2, 3
59 WHT Fuel Injectors 4, 5, 6
60 BLK/WHT GND
Had that all nice anf formated but seems the forum ate my formating.
PNK- pink
BLK black
WHT white
GRY gray
ORG orange
PUR purple
LGN Light green
LBL light blue
BLU BLue
DGN Dark Green
YEL Yellow
