92 2.3 Killing the plug mod......Or not......?
New news, not suprising.... I was sending off my paperwork to get my new sticker and i noticed something missing between my failed first test and my last, (after changing plug wires back).
My first test is missing the RPM field, I don't think the tester had his pick-up lead on the right wire, or not on at all. I grabed all my old test papers and every one of them has a number in the RPM field, except the one I failed.
Glad to waste some time, thanks for your help and input guys.
I have pics, but it says upload or file failed. Maybe someone can tell me how to do this for future reference. Trying jpeg 640x480.
Hmmmm...I got one test result that showed nothing in either idle or higher rpms...it was because they couldn't finish the test due to an exhaust leak flooding the entire bay with noxious fumes...so maybe look for something about test aborted or something...I don't think the computer will allow the test to proceed unless all the connections and input from the operator are correct...on mine they could not enter the VIN number...the computer kept rejecting it...but the plate number was accepted.
Uploading files directly is not supported...you need to create an account with the likes of Photobucket or other and then paste the links from that account into your replies...
There is a stickie on the board...I believe under the section about problems with the site near the top...but if you search for "uploading pictures" or something similar you should hit it...
