scottskipper
Donor: 1993 explorer 4.0 auto
Receiver: 1992 Ranger 4x4 MT
I just swapped the wiring harness in my ranger and it did fit in same as the old one did. Once started plugging things in I found that things were not matching up. First, the xploder had a different brake system and has a large 20+ wire plug that was just to the right of the master cylinder. The Ranger did not have this. Also the wire cluster coming up from the drivers side frame rail with 13 wires does not match any plug in the xploder harness. there are a few more that I have notice but not tracked down yet. Two questions: What should I splice or replace. Or will a 1992 Ranger 4.0L harness be the ticket? Any and all responses are appreciated. Thank You in advance
