- Apr 13, 2009
- '06, '11
- 3.0 V6
- Automatic
1991 ranger 4.0l/5-spd/4x4 race truck
I'm having problems trouble shooting. The wiring diagrams in Chiltons are information overload. I have power to the battery side of the solenoid. No power to the little wire, traced the little red/blue wire back through a connector where it loops back on itself and turns pink and proceeds through the dash to the switch on the steering column. The key pushes a rod that moves the switch from key off through start. I removed the switch and activated it with a screwdriver and still no power to the small terminal on the solenoid. I can jump power from battery side to starter side of the solenoid and the starter turns over but no spark at plug. Can someone run through how the power runs through the wiring in a simple way, I'm lost here. I had the truck running before I r+r the motor/trans, so it may be as simple as reconnecting a wire.
Edit; more info. I checked the starter wiring at the starter, heavy gauge is connected and so is the light gauge. The fender solenoid has all the wires on one side except for the light gauge starter wire. The light gauge key/switch wire at the solenoid is not getting power. EDIS6 is plugged in. All fuses look good. The little timing plug is missing but that shouldn't make a difference? There is no water in the cooling system but it has fired up before like that. Fuel pump is on its own circuit. There is a master power cut-off between battery and solenoid.
Once I get this figured out I'll be cleaning out all the misc. unneeded wiring, that should make it easier to troubleshoot next time.
Thanks,
Richard
Thanks,
Richard
