91' Ranger Brake Fluid Level Connector Wire Color Code..?
snahman
Princeville, NC
Hello..I have to replace the brake fluid level connector as the old one wires just fell out..I bought another one Duralast #870...:confused:..Anyone know the original wiring sequence coming out of the existing loom..?..The color wire on the #870 is.. Middle ( solid blue), One side ( white/red stripe ),Other side ( white/black stripe)..There is no pin indicator markings on the connector..:rolleyes:..Thanks ahead of time...
does this look the same?
Hey Kunar..Thanks for the reply..That could be it for my original wire colors coming out of the harness but they had fell out of the connector, so I'm not sure..:(..But the black solid wire on the new pigtail I bought, is actually on the center pin between the two striped wires..Don't know why they just didn't mark the pins..?....:mad:....BTW, how do you remove the reservoir off the the master cylinder..?..Is it just pressed on ( pull off ) or is it bolted on, tho I don't see a bolt anywhere..?..Lastly, will I have to bleed the brakes by just removing the reservoir..?....Thanks again...!
