91 4x4 manual ranger 4.0 in an 89 4x4 2.9 manual bronco ii wiring help.
nooch450
New Jersey
I just locked my 2.9 right up over the weekend in my 89 B2. I want to swap my 91 Ranger 4.0 into the B2.
1991 Ranger 4.0 with M5OD and 4x4
1989 Bronco II 2.9 prob with the TM trans and 4x4.
I want to swap the entire driveline into the B2 so the 4.0 and M5OD
Here is my confustion. I have read that its plug and play and also that its not.
If I take the ranger engine harness and plug it into the bronco cab will everything work?
For those years there really shouldn't be much of a difference if any.
depending on if your Bronco II dash is a Gen2 dash, which i believe non of them came with a Gen2 Dash, i believe they all came with the ones with wood paneling, aka Gen1 Dash. You would have to splice wires at the firewall. I have an article that will help you GREATLY on this swap.
Here is the Article:
http://therangerstation.com/forums/showthread.php?t=150049
Gen 2 dash. Same as the ranger. I need to repin a few things tho tail lights and rear blinkers plus wipers don't work so far. Neither does fuel pump. Im guna need to look into it more but this is NOT plug and play for anyone wondering.
Sent from my DROID BIONIC using Tapatalk 2
I am currently looking for the PINOUT wiring diagram for the big bulkhead connector that passes throught the firewall on a 1991 Ranger 4.0 and 1989 Bronco II 2.9 so i can repin the connectors to work in one simple spot without cutting wires. I cannot locate this info anywhere. Does anybody have access to these diagrams?
Here is an EXAMPLE of what Im looking for.
http://www.pirate4x4.com/forum/atta...539392-need-94-yj-pinout-diagram-bulkhead.jpg
Its not the same ended up repining a bunch of stuff not only in the big plug but other plugs going to the rear of the truck.
This is prob only plug and play on a 90 B2 to a 90 Ranger. And even than i would be surprised if it was a direct swap.
