high5
- Aug 3, 2010
- Automatic
my '91 ranger 4x4 with 4.0L and auto is used on my inlaws farm for my hunting truck. i use it year round and it is getting warm when just idling around or when parked. i have swapped the fan clutch which did not correct the issue and neither did a new thermostat. in cooler temps i don't have the problem but now that it is up around 100degrees i have started having the issue. if when parked i rev the motor up to around 2500 RPM it will cool back down. also if i speed up, which increases the RPM and air flow through the radiator it also cools down. you can also gather from this that if i run down the road i have no issues there either. just at slow speeds when putting around the farm. any ideas?
