Ranger Tony
Hello...I have available a 91, 4.0 with operating A/C, auto trans, 7' bed that has a perfect body. I shipped the truck from FL to Iowa last Dec. when I moved here; that was the first time the truck had ever been North of the FL state line. The truck has never seen snow, salt or brine. The metal is 100% top and bottom...zero rust anywhere in the vehicle. The suspension was rebuilt 2 yrs ago and has seen about 4300 miles since: ball joints, tie rod ends, shocks, and brakes ( front calipers, pads, wheel bearings, rear shoes and one drum). The transmission was also replaced, with a crate rebuild, 4300 miles ago. The motor is sound with water pump, fan clutch, alternator, radiator coil and 3 injectors replaced within the past 1800 miles. 4 new tires, mounted on the original aluminum rims (very nice condition...no pitting) and center caps 1800 miles ago. The interior...replacement dash cover, new, premium black carpet complements the original red 60/40 seat that is about 85% "as new", door panels are 90% "as new", and the red headliner is absolutely 100 % perfect--no sags, tears or stains. The windshield is perfect (no chips, no runs and no errors) and no wiper tracks...The other windows are original and do have some scratches; but not severe. The bed has a spray on liner and a premium rubber liner both are perfect, a fiberglass tool box w/access from both sides, and the bed is covered with a premium tonneau cover also "as new" condition...no evidence of anything ever being in the bed--ever.
The only known issues with the truck...A. The oil pan leaks (I'm sure the pan gasket is leaking but I don't know if the rear main is leaking or not). B. The gas tank fills very slowly once you hit the 3/4 mark...empty to 3/4 is a normal fill rate; but, that last quarter goes slow.
I had planned to do a 5.0 /manual trans swap but my plans have changed so this truck could be available for someone else to do the swap...This is one of the nicest square body rangers still around and is ready to become either a really neat sleeper or a bold resto-rod. If interested, please e-mail and I will send a complete visual album that should answer any questions you might have....The number is $6k Tony : tonyduprey@msn.com
