900rpm idle
I usually drive 6 miles to work myself. I have to take my truck on a longer trip for the idle to smooth out any time I unhook the battery. At least 30 minutes or so of non-stop driving to get everything fully heat soaked.
Thanks for the reply!
So I’m playing around with it this morning… I put my old IAC valve back on.. sure enough it idles at 900.. the 900 idle was the reason I bought all the new sensors to bring it back down to 700..
Plug my new IAC on and it fires up at 1500… goes down right about 1000… then slowly I’m a up to 1200…
I think when I get home I’m going to clean my old IAC valve and see what happens..
These parts are what 3 weeks old? I hope they stand behind this valve.. it was close to 200 bucks
It’s a motor craft IAC valve too.. I also go OEM to avoid these kind of things..
I find it hard to believe this new one is faulty
That sounds awful. Maybe unrelated, but high idle could be caused by ECT if the computer thinks it's too cold still. By 04 IDK if it still had a separate sender for the gauge or not. Best I can tell from RockAuto, not. So if the gauge shows normal it's probably fine. You could connect a Scan Tool to view the current temperature as a number. That'd be more accurate than the gauge.
Auto parts store says it’s got a 2 year warranty, they ordered me a new one should be here Friday
Here we go again…
Yeah my temp gauge reads and functions like normal. If the new IAC doesn’t fix the issue, the truck has 130k on it, won’t hurt to change that coolant temp sensor
I am having some issues with my idle as well.
After doing some digging, you may try this (I am about to try it for mine). Since yours is an automatic it should be more straightforward. Also, since yours started acting up AFTER you disconnected the battery to work on the starter, hopefully this is all you need to do.
Link: https://www.jbtools.com/blog/how-to-reset-idle-air-control-valve/
UPDATE: new motorcraft IAC valve came in, under warranty.
Installed the new valve, I noticed right away on cold start idle at 1100
She simmered down to 900… I took her for a 8 mile trip, all warmed up.
She’s now purring like a kitten again, idling dead on 700
I honestly can’t believe that motorcraft IAC valve only lasted a month…
But this new one seems to have fixed it!!
Again I want to thank everyone for their help!
I'm going through the same issue. Although just installed new Motorcraft IAC and idle is 2k on startup and 1500 after warm up. Going through everything mentioned in the thread. Vacuum leaks, clean or new IAC, PCV system working etc. Still have the original IAC, might put back in.
