Carter
- Nov 19, 2017
Hello everyone,
I am hoping someone on here can help me out. I have a 1990 Ford Ranger 2.3L. I rebuilt the motor over the summer, when I finished, I test drove it and it ran perfect. However this is where it gets bad. The next day I went to start it up it would not start. I found out the crank position sensor got cut. The harmonic balancer was bent, probably got dropped at one point. Anyways, I replaced the harmonic balancer, and the crank position sensor. Which I thought would fix this issue, but instead I can only get the truck to start and then it dies like a second after firing. Does anyone have an idea of what would cause this? Would the fuel pump cause this if it wasn't giving the correct fuel pressure?
