mapcowboy
- Apr 19, 2013
Hello, I have a bad carbureted '86 2.0 (cracked head, worn out). I recently acquired a complete, 8-plug 2.3 from a '90 Ranger with everything - AC compressor, alternator, coils, sensors - everything that was attached to the engine came attached, including the entire wiring harness up to the firewall. It was a running, driving unit with a bad transmission so they parted it out.
Aside from a different fuel tank/pump/lines, what other electronic (or other) pieces am I missing to swap this into my '86? Or should I try to find a marine intake and go to a carb/distributor? That was my initial plan but EFI would sure be nice. This will be in front of a manual transmission, so I'll need to swap flywheel/flex plate). Thanks in advance for any insight. I don't know what I don't know about EFI.
The '86
The '90 2.3 on the way home
The '86
