90' BII Rebuild----->> Build-up
More of the donor cab
Can a mod please move this to rbvs under construction? Thanks.
You should do a 4.0 conversion, while ur doing all thhother stuff. It would be so easy to do right now. The wiring would be really easy.
looks nice. what are you useing for rear support for the cab?
I would do a 4.0 swap if i had one right now so itll wait. as for the rear cab mounts im doing something similar to the ones maverick made.
so I got all the wiring done today, dash back in and found out it needs a starter solenoid and also a starter. Runs but oil looks like choc. milk and if you stab the throttle at all she dies. tomorrow im going to pick up a starter, solenoid, plugs, wires and possibly cap AND rotor button
Got some more work done. no pictures but heres what i have done.
-new fuel pump
-f150 leafs
-dash all wired up and put together
-chevy one ton front brake hoses
Coming soon is:
-hurculine the floor in cab
-build rear cab mounts
-build temporary flatbed
-run some stuff over
Lookin good, I love the way a ranger looks with the super short bed on a BII frame.
Done quite a bit of work havent posted in a while though. Got the cab on, mounts done. cousin built flatbed in a few hours. Hurculined the floor. I then drove her around a little and found some things that need to be improved apon. Needs an alignment in a bad way. Also need a skyjacker extreme drop pitman arm if anyone has one theyd like to sell. let the picture roll.
Thanks. ive been working on this thing for about a month now after work and on weekends. It was a ton of work but its finally paying off. There seems to be a lot of views but not much posting going on. Anyone else have any imput on it?
